Momentary contact during power On and Off.
Discussion in 'General Electronics Chat' started by sangeetk, May 27, 2009.
  1. sangeetk
    May 27, 2009
    I am new to this forum and my knowledge about electronics is very basic. I am planning to add a laptop in my car which will be used as a carputer.
    My requirement is to make momentary contacts for the power switch both during the power (12 VDC) ON and OFF (to switch on and switch off the laptop).
    I am able to find some circuit diagram which gives momentary contact during power on in the following link
    http://www.the12volt.com/relays/page5.asp
    But not able to find something which also gives momentary contact during power OFF.
    Any help will be really appreciated.
  2. KMoffett
    Dec 19, 2007
    2,584
    234
    The circuit you want is referred to as an "edge detector". The attached are examples.
    Ken
  3. sangeetk
    May 27, 2009
    In the 2nd circuit diagram, instead of reed relay, can we normal SPDT relay?
  4. KMoffett
    Dec 19, 2007
    2,584
    234
    Sure. That's just what I had used to get a long pulse period. The length of the pulse depends on the size of the capacitor and the resistance of the relay coil...mostly. About C (in farads) x R (in ohms) = T (in seconds).
    Ken
  5. sangeetk
    May 27, 2009
    I am facing a problem with the above circuit (with relay), the fuse is keep on blowing.
    The relay which I am using is similar to http://www.blueseaele.com/showprod.asp?id=170 and capacitor is of 470uF. The input volt is 12 vdc. Is there anything wrong with the circuit diagram.
    SangeetK.
  6. KMoffett
    Dec 19, 2007
    2,584
    234
    The schematic is correct. Re-check your wiring.
    Ken
