I want to use a reed switch to trigger an interrupt on an MCU. I only need a momentary action to do this and I want to keep the power consumption low but the reed switch stays closed when the magnet is close. Is the circuit below a sensible approach to getting a momentary action? I've tried it and it works but I just wanted to check that this is a reasonable approach.
