Molex Mini-Fit Jr Connector Mounting Help
Discussion in 'General Electronics Chat' started by minkey01, Jul 6, 2016.
  1. minkey01
    Jul 23, 2014
    177
  2. GopherT
    Nov 23, 2012
    6,303
    4,021
    The 4.2mm pitch could be wired from pins to a 0.1" board with 20 gauge wire and cover the connections with heat-shrink tubing.
  3. minkey01
    Jul 23, 2014
    177
    so the header would be floating around by the wires. hmm.. i think it would need to be secured somehow, so it isn't flapping around and putting stress on the wire connections.
  4. GopherT
    Nov 23, 2012
    6,303
    4,021
    Why? What application? You can also just clip the whole connector and hard wire directly to the board - desolder when needed. Other than that, you'll have to hack together a pcb - I haven't seen adapter boards for 4.2 mm connectors.
  5. minkey01
    Jul 23, 2014
    177
    ok. thanks. looks like i should probably get a custom pcb made.
