Moisture sensitive 4017's?
Discussion in 'General Electronics Chat' started by magnet18, May 16, 2011.
  1. magnet18
    Thread Starter Senior Member
    Dec 22, 2010
    1,232
    125
    Alright, I recently got a bunch of parts in the mail, and I thought I got some normal 4017's, just the cheapest ones I could find. 11MHz, 6-20V, all normal, right?
    Well, when they showed up, they were in a solid silver bag, which I haven't opened yet, but on it it says they have an out of bag life of one year and may require baking before mounting and etcetera.
    Can I still use these like normal, or should I order new ones?
    And what exactly are they?:confused:
  2. #12
    Nov 30, 2010
    16,670
    7,314
    I never heard of that. Perhaps they are really potato chips that would get stale in a year and need to be baked a bit.
    Open the bag and see what you have. Some places do labels badly, like sending me 3 amp fuses marked, "static sensitive".
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    It does sound a bit bogus. Old parts can be hard to solder, but not in the time frame you are talking about. It takes years, and basically the tin oxidizes and solder doesn't stick well anymore (think of it as rust). Solder flux can help if it is a problem.
    Your specs sounded way off, so I looked up a datasheet. CMOS has wide voltage specs (3V - 15V)...
    http://www.national.com/ds/CD/CD4017BC.pdf
  4. magnet18
    Dec 22, 2010
    1,232
    125
    My bad, it has an input of 3-20V
    part number HCF4017BEY, manufactured by stmicro
    I opened it up and it had a humidity meter and there were like 5 packets of silicon dioxide in it(that stuff that says "do not eat").
    datasheet says 10mhz, the package I'm holding says 11...
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    The one I posted says 5Mhz (I think). What does your's say the maximum current out is? I'm used to 6.8ma for the spec.
    You can't go wrong with too many gel packs.
  6. t06afre
    May 11, 2009
    5,939
    1,222
    Oxidation my very well be a problem in an automated soldering process. but for a hobbyist using manual soldering. Not very likely , but the components may be somewhat solder to solder if the pins are very oxidated. This is here the solder flux come in. Solder flux is a chemical cleaning agent that facilitates soldering, removing oxidation from the metals to be joined
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Believe it or not, it's due to the plastic packaging absorbing some moisture over time, and during oven reflow soldering, the package temp can get hot enough to boil water. If there is moisture absorbed in the plastic and it boils, it will rupture the IC package.
    This kind of thing really isn't a concern for hobbyists. In a production house, IC's that had been around too long would either be put on the surplus market, or they would have to be baked in a vacuum oven to draw the moisture out prior to board assembly. Otherwise, the completed boards could have an unacceptably high failure rate.
    magnet18 and #12 like this.
  8. tom66
    May 9, 2009
    2,613
    214
    It's not bogus at all. Moisture inside the casing can cause microfractures which can damage the IC especially during soldering or reflow. I have several other parts with the same markings.
  9. #12
    Nov 30, 2010
    16,670
    7,314
    Thanks, Wookie. I learn something new every day.
  10. magnet18
    Dec 22, 2010
    1,232
    125
    10mA!!
    Part page
    Datasheet
    I got mine for 20 something cents a piece :cool:
    They were on sale.
  11. Kingsparks
    Member
    May 17, 2011
    118
    5
    Hi.
    I know this is an old thread and I'm new but couldn't help it, I broke up over the "static sensitive" 3A fuses. I got one almost as good, a bag of sockets, about 50 various types, 4, 6, 8, 14 etc DIP sockets marked, yep, "static sensitive" and in a real nice anti-static bag. No joke, er, maybe joke after all.
    Roland
  12. #12
    Nov 30, 2010
    16,670
    7,314
    @Kingsparks, 25 hours isn't considered old here.
    ps, thanks for helping me. I try to crack this place up, but emotions don't travel well through wires.
  13. magnet18
    Dec 22, 2010
    1,232
    125
    I've had the same thing happen as well. :p
    And I love when TVS diodes (they are used to stop lightning for petes sake) show up in static bags :rolleyes:
    And I just posted a couple hours ago in this thread... what forum did you come from? ;)
  14. Audioguru
    Dec 20, 2007
    9,411
    896
    I have heard about LEDs having a warning to bake them before soldering them if they were in a humid environment. So I think your HEF4017 ICs and the 3A fuses were simply packaged in the wrong bag that had the warning for LEDs.
    The typical output current of a CD4xxxxB IC is 6.8mA when it has a 15V supply and a voltage across its output transistor of only 1.5V. If the supply is 15V and the output transistor has 13V across it because it is driving a 2V red LED then the current is typically 29mA and the output transistor will melt with a power dissipation of 13V x 29mA= 377mW unless it is run through 10 steps very quickly.
  15. nbw
    Member
    May 8, 2011
    36
    10
    Does the datasheet specify a humidity rating at all, other with min/max temps? I remember in Singapore we had problems with humidity affecting quite simple electronics circuitry.
