I had never heard of this device. Does any of you know of any practical applications?
And how is one supposed to hook it up, since it doesn't have two extremes?
Now I get it... the figure in the article shows how to hook it up. One electrode on one side, and the other directly opposite on the other "side". It also mentions that "... it can resist the flow of electricity without causing magnetic interference at the same time." So I guess it has to be for AC applications... but which ones?Assuming an equal resistance per length, The highest resistance is between any two points that are directly across from each other. That's all I have.
If your twist a round wire, how does it "know" it has been twisted?Never heard of one either. After reading up on them. The best thing that I can relate it to is a Non-inductive wire wound resistor. I was hoping that I could find a schematic that uses one. I did read they are used in high frequency applications but the frequency was not mentioned.
Very interesting article, thanks.As discussed here, it's designed to have very little self inductance for use in high frequency circuits (those at which the self inductance of a resistor can be a problem, such as microwave frequencies). It's purpose is the same as conventional non-inductive resistors but is likely better at minimizing the inductance since the current over every surface of the resistive conductor is matched by an equal and opposite current on the opposite side (of course technically a Möbius strip only has one side ).
Apparently he's referring to the Ayrton-Perry wound resistor that's designed to cancel inductance as well:If your twist a round wire, how does it "know" it has been twisted?
John
I'm nearly round and have certainly been twisted.If your twist a round wire, how does it "know" it has been twisted?
Yes, I found it quite humorous too... sorry if my wit seemed a little dry on that one at the time...A single round wire doesn't have the necessary insulating layer in the center. That's why it can't tell if it's been twisted into a Mobius loop. Still, I found the simple interpretation of the idea quite humorous. Thanks for the LOL.
I'm laughing here... thanks... now I can hit the sac wearing a smile instead of worrying about paying tomorrow's bills...Quick! Erase that last sentence! The audiophools will be on that term like, "oxygen free" copper.
