I am working on a car project, and I may need to build a little hack to make a transplant engine behave correctly. Unfortunately, I don't know much about circuits, yet!
The circuit will need to read the engine RPMs and based on that, operate a couple of switches. Problem is they don't just open at particular RPMs - they close at certain other RPMs too. So how could I build a circuit to operate them? The RPM signal is a variable voltage.
There are three states besides the 'rest' state. I wrote some peseudocode for how it should behave:
switch a = default state CLOSED
switch b = default state OPEN
states:
idle - a closed, b open (no action required)
<3400 - a closed, b closed (b operates)
<4100 - a open, b closed (both operate)
>4100 - a open, b open (a operates)
if((rpm>1200) & (rpm<3400)){
switch b
else if((rpm>3400) & (rpm<4100)){
switch a
switch b
else if(rpm>4100){
switch a
Can anyone help me get on the right track with building this please? I don't need an exact diagram or anything, just an idea of which components can be used to do what. Thanks.
states:
switch b
switch a
switch b
else if(rpm>4100){
switch a
