modulating light
aac9876
Joined Dec 9, 2006
124
one of the companies on my stock watch list makes products that modulate
light waves for electronics uses. Optical nubiate. etc or something.
Light cant be measured by frequency right.?? How could you read little
bits of modulated light waves. ?? Would it be similar to radio freq. ??;):eek:
hgmjr
Joined Jan 28, 2005
9,027
I believe that some of the old laser based distance measuring equipment had a light modulator that could modulate the intensity of the aggregate laser beam.
hgmjr
Papabravo
Joined Feb 24, 2006
21,225
Since light is the same kind of electromagnetic radiation as radio waves it certainly can be "measured in frequency". It follows the the same relationship as radio waves, namely:
Rich (BB code):
c = f * lambda
where c is the speed of light, approximately 3e8 meters/second
and f is the frequency in Hertz
and lambda is the wavelength in meters
bloguetronica
Joined Apr 27, 2007
1,541
The beauty of using light, is that you can use several wavelengths in one cable, and they won't interfere, since they can be separated by simple optics.
thingmaker3
Joined May 16, 2005
5,083
Yes. Multiple propagation modes allow effective transmission at different simultaneous wavelengths. As an example, we can transmit at 850u while recieving at 1300u. (Assumes we are using the expensive cards.)
In common practice, only one wavelength is used, and xmt/rcv are on different fibers. This uses affordable cards.
