Hi there, i'm building a modular synth at the moment & I've been coming across the following problem.
Some of the modules seem to interfere with other modules even when they are not patched together, Example:
lets say I have an oscillator patched straight to a mixer with no other modules connected to it, no modulation or cv control etc.... Now all the other modules like LFO, envelope generators or anything that generates rhythmic patterns or modulation( mainly with leds ) will interfere with the Oscillator pitch ( very slightly, like a light vibrato, depending on the rate of the other modules ) even thou, like I mentioned before not directly connected to the Oscillator!!
the only connection is: they are all connected through a bus that connects to a power supply.
I'm using bi polar Power supply 12+ 0 12- but not all modules need bi polar, some designs are 12v single rail.
I have tried another power supply but with no luck, still the same!
Everything else is working well, & I have done filtering caps on power rails for each module & I have checked all circuits?!
I have different oscillator designs, but this problem affects all of them.
I have been building circuits (mainly music stuff ) for some years now, but my knowledge is still limited when it comes to problems like this. I would very much appreciate some help & apologies for my English as it is my second language & sometimes I find it difficult to explain in writing
many thanx , Jackos
many thanx , Jackos
