Modifying LM350 need help!
Discussion in 'The Projects Forum' started by ayane, Sep 30, 2009.
  1. ayane
    Thread Starter Active Member
    May 3, 2009
    hi, i had built a simple regulating with this ic with sets the voltage ouput around close to 19v.
    r1- 120 ohms and r2 1680ohms.. The ic i bought is the adjustable output voltage type. My input is 21V
    I was wondering how do i modify this circuit so that i can multiple voltage outputs?..such as 15v,16v,18,19,20,etc..
    Any ics that can be used?..prefer those with high output current of about 3A..thx..
  2. t06afre
    May 11, 2009
    You could perhaps use a potentiometer and a knob with a scale. Or buy a cheap panel instrument
  3. rickmartin
    Sep 26, 2009
    If you are talking about SELECTING specific voltage outputs, rather than having the continuous control a pot provides, you could replace the pot with fixed resistors and switch them into the circuit with a multi-pole switch. You would have to use the pot, first, to get the proper resistance for each output voltage. The LM350 is a really sweet regulator. I have used them to drive 3055 transistors for high current applications and never had one fail.
