Hi Guys,
Can you suggest a circuit add-on which can produce a signal with shorter duty cycle (or smaller pulse width)? Pls refer to the attached picture file. Pin X has a square pulse train source while Pin Y needs to tap from Pin X connection. Please note that the high voltage level is at 4V while the low voltage level is at -0.1V.
Thanks!
Thanks!
