modifying beep in existing circuit.
Discussion in 'General Electronics Chat' started by avocadobaby, May 5, 2010.
  1. avocadobaby
    May 5, 2010
    Hi, I'm a circuit noob, I can solder a little, and i've made simple circuits using a screw board from an electronics store.
    I have a machine with an annoying beep, high pitched and loud.
    Is there an easy way of modifying the beep pitch/volume by cutting off the speaker and reconnecting it with some simple circuitry between the speaker and the rest of the circuit without changing anything in the current circuit board?
  2. Bychon
    Member
    Mar 12, 2010
    469
    41
    Is it a speaker or a little piezo squeeker? Most people just disconnect the piezo devices. I stuffed some electricians putty in mine. (Electricians putty is like clay or Play-dough, except it doesn't harden for several years.) It works if all you want is silence.
  3. BMorse
    Sep 26, 2009
    2,675
    234
    or masking tape over the "beeper" hole will silence it also, but not disable the tone. You can always post some pics of it so we can determine what type of beeper/buzzer it is to be able to give better advice, maybe if it has some specs on it you could post them on here. (usually this info is printed on the back of the housing.) It could be just a matter of getting a replacement with less Frequency(Hz) and with lower decibels if it is a piezo.
    B. Morse
