How is possible wireless doorbell circuit diagramm modify so, that becom remotely operated switch, what funcion so, that when press transmitter button, engage resiver relay and when transmitter button disconnect,
disconnect resiver relay instantly.
There isn't too much to a wireless doorbell. It should be possible to examine the receiver and alter it to do the activate relay function. When it receives a valid code, so signal has to activate the chime function.
It should be doing that already. If it is not, you might have a button that is sticking on the transmitter, a relay that is sticking on the receiver, or you might have radio interference from some other transmitter that is keeping the relay energized.
Just tried my wireless door bell. Pushing and holding the button looks like it sends out only one coded signal. Holding it down doesn't repeatedly ring the bell. He may have to go to a push-on/push-off operation, with a toggle circuit at the receiver.
haha wireless doorbells are funny. it may not be wt you asked for , but you may try to test if it is working by using the off button on a tv remote control. works for ours =)
Well, think about how hard it would be to use IR to signal from a door to an annunciator around a corner in a different room. Anything that bright in the IR region would probably set the opposite wall on fire.
I have converted a wireless door bell to operate a relay.
Checked voltages on the receiver until I found one that would drive a transistor that would drive the relay.
As resacejr said the relay will only be on for a few moments and will need a ratcheting circuit
