Modification to a microcontroller led driver circuit.
Discussion in 'Embedded Systems and Microcontrollers' started by illusive, Sep 4, 2015.
  1. illusive
    Jul 9, 2015
    46
    I was in a search for a good 20 leds bar graph audio meter and i come across this simple solution with Attiny13.
    http://www.hobbielektronika.hu/forum/getfile.php?id=47842
    But i want to add some kind of glue circuitry on the five outputs/inputs of the microcontroller that drive the leds so i can get more current out. The Attiny13 can output up to 40mA per pin. Also if it is not too complicated i want to add some kind of brightness control.
    Is all of this doable?
    Edit: One more question, can you confirm that the circuit can drive the leds in bar mode and not just in dot mode? Here are the C codes:
    http://m.eet.com/media/1185436/1200...ms_for_linear_and_logarithmic_scales_zip_.zip
  2. Alec_t
    Sep 17, 2013
    5,979
    1,138
    Bar mode would require up to 20 times the single LED current, so the Attiny total output power rating (I haven't checked that) might be exceeded. For example, assuming the micro runs from 5V and you want 20mA per LED you are asking the micro to dissipate up to 2W.
    Brightness control is certainly doable, with PWM.
  3. illusive
    Jul 9, 2015
    46
    That's why i'm not sure how to set the circuit in bar mode and is it even possible. The article says that it can, so i assume it is code related, but i'm new to microcontrollers and i'm not sure what to tweakin the code.
  4. John P
    Oct 14, 2008
    1,638
    225
    Current output is 40mA max per pin, but there's also a maximum current rating of 200mA for all pins together. That would be only 5 pins each sourcing the 40mA output, or 10 pins each sourcing 20mA.
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
  6. illusive
    Jul 9, 2015
    46
    Ok thanks for the info. The way the circuit and the code is given, does it operate in bar mode? I mean are for example all the 20 leds turned on when the input signal is at it's max level or is just the twentieth led turns on?
  7. atferrari
    Jan 6, 2004
    2,670
    785
    I aim higher. Google gugaplexing.
