I am trying to modify this circuit to be activated by a smartphone headphone output. Do you think it is possible?
http://www.kitsrus.com/pdf/k126.pdf
Thank you,
Tim
Thank you,
Tim
Replace the mic with an identical resistor to R8 - that biases the op-amp input to 1/2 Vcc, you need a DC blocking capacitor say about 0.1 to 0.47uF. Its probably a good idea to include a load resistor on the phone side of the blocking cap, probably about 32 or 64R - but the DC winding resistance of a headset as measured should be close enough.I am trying to modify this circuit to be activated by a smartphone headphone output. Do you think it is possible?
Thank you,
Tim
by Jake Hertz
by Dale Wilson
by Duane Benson
by Duane Benson
