Modern Electronic and Electrical Aircraft
Discussion in 'General Electronics Chat' started by cheyenne, Mar 23, 2008.
  1. cheyenne
    Thread Starter Active Member
    Dec 6, 2007
    48
    Hi, does anyone know any good resources on the internet for the topic of modern electronic and electrical aircraft as I'm not having that much luck. Thanks.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I'm not trying to be dense here, but the concept of an "electrical aircraft" brings old movie serials to mind. Do you mean an RC airplane that uses electric motors?
    "Electronic aircraft" is a bit of a stretch, too. Are you referring to fly-by-wire controls?
  3. cheyenne
    Dec 6, 2007
    48
    Yes "fly-by-wire" and navigation etc.
  4. n9352527
    Oct 14, 2005
    1,198
    The correct term, I believe, is avionics. You might have more relevant results by searching that keyword instead.
  5. cheyenne
    Dec 6, 2007
    48
    Thanks, I've found a lot of info searching that term!
  6. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    If you get a chance you should try and get hold of the Jeppesen books which cover, amongst many aircraft-specific subjects, the topic of avionics in quite some detail. I survived on these things when I was an apprentice.
    Dave
