Modelling a serial transmission system in VHDL
andy24691
Joined Nov 25, 2010
42
I have to design and build a system capable of the following;
1) A 4-bit number is to be obtained from a 4-bit dil switch and on the press of another switch the 7-bit ASCII equivalent is to be transmitted via a simple synchronous serial comm link.
2) The comm link is to operate on ttl levels and comprises three wires: data, ground and clock.
3) A receiever is to detect when a transmission has ocured and display the hexidecimal equivalent on two 7-seg displays.
The code below is for the transmitter, I'm not very knowledgable when it comes to VHDL so I apologise if its filled with 'obvious' errors. To the best of my limited ability I have attempted to debug the programme but it refuses to compile. Could anyone be able to help me out? Please reply in the simplest possible terms.
Cheers
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity transmitter is port(
bin: in unsigned (3 downto 0);
sout: out std_logic;
shift, load, clk: in std_logic);
end transmitter;
architecture module1 of transmitter is
begin
process(bin, shift, load,clk)
variable temp: unsigned (6 downto 0);
variable index: integer;
begin
if load ='1' then
case bin is
when "0000" => temp:= "0011110";
when "0001" => temp:= "0011111";
when "0010" => temp:= "0100000";
when "0011" => temp:= "0100001";
when "0100" => temp:= "0100010";
when "0101" => temp:= "0100011";
when "0110" => temp:= "0100100";
when "0111" => temp:= "0100101";
when "1000" => temp:= "0100110";
when "1001" => temp:= "0100111";
when "1010" => temp:= "0101001";
when "1011" => temp:= "0101010";
when "1100" => temp:= "0101011";
when "1101" => temp:= "0101100";
when "1110" => temp:= "0101101";
when "1111" => temp:= "0101110";
end case;
end if;
if shift = '1' then
index := 0;
else if shift = '0' then
index := 7;
end if;
while index < 7 loop
if rising_edge(clk) then
temp:= temp ror 1;
sout <= temp(6);
index := index + 1;
end if;
end loop;
end if;
end process;
end module1;
