Looking for some pointers towards modelling the current at each junction in this parallel circuit.
I'm using iCircuit to model it, but I can't export its data readings to my custom software.
The voltage is attached at the top-left. I move the ground connection around and connect it to each junction. Each resistor is 1 Ohm.
I'm not looking for a step-by-step or handholding, just a tip on a reasonable place to start. I understand the basics of parallel resistance. I don't understand how to build them up in a way that model the current flow in this circuit.
Thanks!
Thanks!
