I cannot figure out what I'm doing wrong. I have a model train turn-out that has a wired remote to control the switch. To activate the switch, I can apply 9-19 VDC momentarily to flip the switch and I'm trying to use a transistor to control the switch. I already have a circuit that will apply a momentary voltage, for instance, to a base of a transistor. I was thinking I would have this other circuit apply a small current to the base of a transistor and the emitter would be connected to the switch to apply the voltage and trigger the switch on the turn-out. But it doesn't work. I've tried various configurations with NPN (2N4401) and PNP (2N4403) transistors, and even a TIP130. But the switch on the turn-out will only trigger if I directly apply the voltage to the leads directly to the switch. Can I be missing something? If I measure the coil resistance it is 20 ohms. Are there any suggestions of what I should try?
Thanks,
Ken
Thanks,
Ken
