Model Railway Control Panel
Discussion in 'The Projects Forum' started by siweckp, Oct 24, 2013.
  1. siweckp
    Oct 22, 2013
    6
    Hi
    Î'm a newbie here so hopefully I've landed in the right thread area.
    In the attachment is schematic control panel idea for my model railway. As an absolute dummy regarding wiring can anyone suggest to me how to fulfill this wish.
    Most important for me are the amp measurements and the main Voltmeter.
    Q: Can I use breadboards?
    Q: Are there Standard wiring methods for amp/Voltmeter measurements
    Q: I hate soldering. Is there a way to connect without?
    Happy for any suggestions/ideas
    Best regards and thanks in advance to you all.
    English Pete
    Switzerland
    http://www.siweckp.com
  2. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,511
    I would say Definately Not, not if you want reliability!.
    Yes there are typical methods, but if using simple analogue meters then all you need is a volt meter and a series shunt if measuring using a analogue meter for DC current.
    If your original meaning was for wiring the whole panel, it looks like a job for a PLC of some some kind?
    Max..
  3. siweckp
    Oct 22, 2013
    6
    Hi Max
    Thanks.
    Rgds.
    Peter
