Hi All,
We were given to model a MOSFET in PSPICE, and we needed to change some parameter like
Lambda, Vto, W, L, Kp or Kn; Below is the list of paramterers. I am using Orcard Capture lite v16.6.
My problem I dont where to modify these parameters.
First I try:
Right Click on Part --> Edit Pspice model and then Copy and Paste the parameters below and change those to the values I had.
The circuit analysis was not close to my calculations.
Second Method:
Double Click on part --> Opens a Part properties. I only saw the W and L; I change those and I was able to get a much closer result to my theory calculations. But still I am not close..
For VD I am getting 13.5v and it should be 13.02v
any Ideas on what I am doing wrong
thanks
Gera
model MbreakN-X NMOS (Level=1 Gamma= 0 Xj=0 Tox=1200n Phi=.6
+ Rs=0 Kp=111u Vto=1.2 Lambda=0.01 Rd=0 Cbd=2.0p Cbs=2.0p Pb=.8 Cgso=0.1p
+ Cgdo=0.1p Is=16.64p N=1 W=30u L=10u)
First I try:
Second Method:
thanks
Gera
