I wonder how many of you have these problems, and who has actually done anything to rectify it.
In my case, being a salty environment, not to mention the dust accumulation, I have had a lot of issues regarding copper tracks and exposed solder joints forming oxidization.
PC components being expensive and very effective in collecting dust, especially the expansion cards like graphics and sound cards, I have had bad experience about card failures due to salty dust collecting on top side of the cards ( side facing upwards ).
Cleaning is not effective once the degrading had started. Not to mention the unavailability of cleaning agents that are effective in removing the oxides and dust.
Since I am assembling my new workstation, ( the components have been bought for quite a while now ), I have been thinking before assembling I have to do something quite effective for this problem.
Since I have high temp resin compound which is used to encase electronics, I thought of an idea. But to make sure I do not destroy an expensive graphic cards and such, I have to test using another working card. Going through my junk I found the one below.
Which is quite clean but has started to rust somewhat. Card is assumed to be working since I do not throw away any working ones. It was a left over from my current upgrades to Audigy ZS.
You can see the dust accumulation.
All I need to protect is the top side. Which is always the side collecting dust.
After a thorough cleaning using thinner the card is prepared as below
You can see what I did to prevent the resin from dipping from the sides.
The side are enclosed by plastic I found lying around and is held by super glue and wood glue is used to seal the side from leaking.
Now the resin has been applied and left to dry. We'll see after it had dried.
Till then
Cheers
Till then
Cheers
