Modding wireless burglar alarm
Discussion in 'General Electronics Chat' started by abjay, Mar 26, 2014.
  1. abjay
    Mar 14, 2014
    7
    I have a wireless burglar alarm that I want to use to operate a door release latch (8-12V). The alarm unit has a pir and a sounder and operates off a 6V battery pack, armed and dis-armed by a key fob with a 30sec delay. Is this an easy mod or is it more trouble than it.s worth? Any suggestions welcome.
  2. Dodgydave
    Jun 22, 2012
    5,150
    769
    you could wire a relay across the sounder if its an on board type and not a speaker.
    abjay likes this.
  3. abjay
    Mar 14, 2014
    7
    it is an onboard sounder, but how would I overcome the delay and how would I get the voltage up to the release, as you might guess I'm a novice
  4. Dodgydave
    Jun 22, 2012
    5,150
    769
    altering the delay would need more studying of the circuit inside, the relay can be wired across the sounder, and use the relay contacts to power the bolt.
