Modbus Circuit, Laptop with Modscan and one device
Discussion in 'The Projects Forum' started by skylight, Jul 16, 2014.
  1. skylight
    Jul 16, 2014
    Hi everyone,
    Sorry if my inquiry seems basic. I do have some modbus instruments, one of them is a CAMERON MC-III, which is really a turbine meter flow computer. Now, here's the thing: HOW CAN I CONNECT TO IT TO READ/WRITE REGISTERS USING MODSCAN/MODSIM? Remember, I do not want to connect to a full modbus network with several slaves, I just want to connect to this single device with my laptop. So far, I have tried to connect using a MICROFLEX USB to RS485 converter, directly to the modbus pins of the instrument (+ and -), but that does not work at all. I have also tried to connect to it placing a 120hms resistance in parallel but that does not work either. This device talks modicon modbus RTU, which I guess is the standard version, but even so I have tried to set it to Enron, Daniels, etc, and it's not working either. I have also made sure that both the MICROFLEX converter and the modbus device have the same baud rate, bits, etc, etc, etc...
    I am not too sure of what the right circuit should be. Am I missing something? do I need a power supply in series or something like that? I really do not know, as I do have more slaves to connect to make a fuller network. In addition, what voltage (DC) could I expect to find in both modbus pins to make sure the unit is trying to communicate?
    I have also tried to connect the unit to a NET485 device (made by GRIDCONNECT, s Modbus RTU to Modbust TCP converter) but although MODSCAN detects the NET485 itself, it is not receiving any information from the modbus unit, I guess the same circuit configuration problem... So I can't read it directly using the USB to RS485 converter or through a MODBUS RTU to MODBUS TCP Converter...
    Thanks to whoever might help and sorry for the long explanation...
