I am given an assignment by my lecture. We are using two 74LS93N(4 bit binary counter) ICs to build a 60 seconds stopwatch. I have no problem building MOD-60 counter from 00 - 59 and it will reset to 00 when it hits 60. I have connect the these two 74LS93N to two 7 segment LED common Anode. I use MOD-6 and MOD-10 to come up with the MOD-60 counter.
However, I do not know how to add in stop/start and reset buttons. The reset button switch will clear or reset the mod-60 counter to 00 when activated. ie, 00 until it is started again through the use of the start/stop switch.
If the mod-60 value is running , activating the start/stop switch will stop the counter at its current count value, ie, 40, which indicates a time lapse of 40 seconds from the start. Reactivating this same switch will cause the mod-60 counter to resume from this previously stopped value.
We are given one 74LS00 and one 74LS32 as well.
If possible please upload a picture of it thanks!
