MOD-13 counter
Discussion in 'Homework Help' started by tunexy2001ng, May 26, 2014.
  1. tunexy2001ng
    May 26, 2014
    Evening guys... Pls i need your help on this assignment. (1) Using any simulation tool of your choice, design a MOD-13 counter using commercial J-K flip flop. The output should be monitored with four LED'S as well as 7-segment display
  2. WBahn
    Mar 31, 2012
    18,080
    4,917
    There's nothing for us to help with until you show YOUR efforts to work YOUR assignment.
  3. JoeJester
    Apr 26, 2005
    3,393
    1,211
    Can you sketch out a functional block diagram?
  4. tunexy2001ng
    May 26, 2014
    attached within is WHAT i have tried to do. Pls help
  5. shteii01
    Feb 19, 2010
    3,500
    511
  6. JoeJester
    Apr 26, 2005
    3,393
    1,211
    Ok, you have a four bit counter.
    Can you name the functions you will need to complete this task?
  7. WBahn
    Mar 31, 2012
    18,080
    4,917
    I would not recommend using that topology. The problem is that it uses gated clocks. As soon as you add any additional logic you are likely to produce glitches on your clock lines and get unpredictable behavior. Better to stick to a fully synchronous design in which all clock inputs are driven from a single free running clock signal.
    absf likes this.
  8. tshuck
    Oct 18, 2012
    3,531
    675
    I will second the call for a synchronous design.
    This thread details a design approach for a Mod-3 and a Mod-10 counter - extending it to a Mod-13 counter is not difficult, is a matter of filling out your state table accordingly and following the same steps as explained.
    absf likes this.
  9. Jayaraj kenche
    Oct 4, 2014
    what is your requirement.?
    Counters are of two types.
    1.synchronous
    2. Asynchronous
    in the above thread , the circuit u have considered was asynchronous counter
