MOC3022 Optocoupler Testing
Discussion in 'General Electronics Chat' started by Randa Mohamed, Nov 25, 2015.
  1. Randa Mohamed
    Jun 19, 2015
    25
    Hello everyone
    I have purchased around 15 pieces of MOC3022 and they are not working ? Not even a single one, How can I test them with an LED for example ?
  2. crutschow
    Mar 14, 2008
    13,475
    3,362
    How did you test them to know that they are not working?
    To test those isolators that have a triac output, you need an AC source (such as from a transformer output isolated from the mains) and a DC source for the control.
    If you want to use LEDs as a load then you could use two connected in inverse-parallel with a series resistor to limit the current well below the LED's maximum current rating.
    The input control should be a DC voltage in series with a resistor to limit the current to about 20mA.
  3. Randa Mohamed
    Jun 19, 2015
    25
    I have used the diode testing option in my multimeter
    Could you provide a schematic for your suggestion ?
  4. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    For an application sheet see Fairchild AN-3006.
    These are random phase opto couplers.
    Max.
  5. dl324
    Distinguished Member
    Mar 30, 2015
    3,376
    651
    Insert LEDs in series with RL in this circuit:
  6. Randa Mohamed
    Jun 19, 2015
    25
    @dl324 I have constructed the schematic you provided, I ignored the diac part, i set the input resistance to 300 ohms the i've connected an LED to the base pin of 2n3904 and there was no output, i removed the led and measured the output using the multimeter but it gives 0 volts
  7. Randa Mohamed
    Jun 19, 2015
    25
    12283136_969394273148990_44146943_n.jpg This is my circuit
  8. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    Try without the 2n3904 and take pin 2 directly to supply common.
    What AC load are you testing with?
    Max.
  9. Randa Mohamed
    Jun 19, 2015
    25
    I wanna control a triac, this is my schematic
    What do you mean by "supply common" ? Sorry English isn't my first language
  10. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    Common = GND in the schematic.
    I see you have done it.
    Max.
  11. Alec_t
    Sep 17, 2013
    5,968
    1,135
    Between which two points did you measure the output?
    Did you have your DMM set to measure AC volts?
  12. Randa Mohamed
    Jun 19, 2015
    25
    @Alec_t
    I've measured the output between the 10 kohm resistor legs, I used DC volts because im supplying the optocoupler diode with 5V from the arduino
  13. Randa Mohamed
    Jun 19, 2015
    25
    @MaxHeadRoom
    Yes I've done this and when I measured the dc volts between pins 1 and 2 of the optocoupler I got a voltage drop of 1.7 as I remember. The measured voltage matched my calculations but when I tried to measure the current I got 0 amps. That's why I was suspicious.
  14. Alec_t
    Sep 17, 2013
    5,968
    1,135
    :confused: I don't see a 10k resistor in your circuit ?
    Current in which path?
  15. Randa Mohamed
    Jun 19, 2015
    25
  16. dl324
    Mar 30, 2015
    3,376
    651
    I meant put two inverse parallel LEDs in series with RL. When you pulse the transistor, the diac should trigger and the LEDs would indicate that.
    You don't need the transistor; I copied the test circuit from the datasheet.
