MOC3010 Vs MOC3042 Help
Discussion in 'Embedded Systems and Microcontrollers' started by RobbJohnson, Oct 19, 2011.
  1. RobbJohnson
    Thread Starter Active Member
    Dec 15, 2009
    76
    This circuit is switching 30 Volts AC with an input from a pic controller and has been working for years. I would like to know if the MOC3010 can be replaced with an MOC3042. the only difference i see is the
    3042
    OPTICALLY COUPLED BILATERAL
    SWITCH LIGHT ACTIVATED ZERO
    VOLTAGE CROSSING TRIAC
    and the 3010
    SWITCH NON-ZERO CROSSING​
    TRIAC
    I am not sure if this will effect the circuit. and help would be appreciated.
    Robb
  2. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    That depends on what you are doing.
    If you are trying to dimm the AC voltage, the 3042 will not work.
    If you are only switching the AC on and off , the 3042 will work.
    Bertus
  3. RobbJohnson
    Dec 15, 2009
    76
    I am just switching the 30VAC on and off. It part of a antenna rotor control system. Thanks for the information.
    Robb
