Hi All
Back to the scooter again. I have not been well for a bit so not done anything to it. Anyway I have been tracing the wires and building up a picture and drawing it I now just need to split the back end away from the scooter so I can get access to the main controller as there is a 14 pin plug I need to test and trace the wires to.
As I need to find out if there should be voltage to the small red wire one pin 1 of the main connector plug and which pin this corresponds to on the 14 pin plug of the main controller. As I should think that with 24v going into the controller there should be some voltage out to power the ignition and ancillarys Dont you?
So now I just need to get the controller off and test the 14 pin plug and is why I have not listed anything on as yet.
Os
Os
