1. There are three terminals in mobile li-ion battery. Two are +ve & -ve. What's the third one.
2. I want to make digital voltmeter using MCU.
How do they measure voltage by using float voltmeter. +ve lead I can connect to input of adc pin o MCU. How to make -ve lead of it. Will it ground of MCU. If yes, can I measure flaot voltages.
Usually specs in DMM are like 10M while measuring voltage. How this thing can be implemented in my ckt. Should I add separte 10M resistor, or internal imepdence of pin is high.
How resistance are measured in DMM. How does it vary with different ranges like 100, 10K,1M
