Hi all,
I have a Omron MK2P-S relay that I wish to use to automatically switch from my wind generator/inverter power supply to mains power supply when the battery power gets low. can anyone tell me the pin identification as I can only see numbers 1-8 which mean nothing to me. I believe these are the connections i need to identify:-
Inverter Live to Relay Coil
Inverter Neutral to Relay Coil
Relay COM1 to Lighting Circuit Live
Relay COM2 to Lighting Circuit Neutral
Mains Live to Relay NC1
Mains Neutral to Relay NC2
Inverter Live to Relay NO1
Inverter Neutral to Relay NO2
So if someone can put the correct pin number to each connection I would appreciate it.
Thanks in advance.
Thanks in advance.
