I have an old VFD type device that has six of these units. It did work, one day something in it popped and it died. Visual/smell test lead nowhere.
The device has a rectified DC supply in it which feeds to the drive circuit that has 6 MJ10000 transistors on small heatsinks.
The issue was that once you tried to apply output power the small internal breaker/switch would trip. I removed the DC supply to the transistors and the issue stopped. This leads me to think one or more transistors failed.
I'd like to test these transistors, but not sure what the best way would be besides maybe ohm test and I'm not sure what a reasonable value would be or proper polarity lead to transistor pin for testing.
