mixing two different frequency signal
Discussion in 'General Electronics Chat' started by sribalaji, Dec 15, 2011.
  1. sribalaji
    Dec 15, 2011
    what will be the resustant frequency of the signal if suppose i mix two sine wave signals of equal amplitute and different frequencies(50hz and 60hz)?
  2. Jotto
    Member
    Apr 1, 2011
    159
    17
    sum and difference.
    sribalaji likes this.
  3. Ron H
    Apr 14, 2005
    7,050
    657
    It depends on whether you want a linear mixer (summing), or a nonlinear one (multiplying). In the first case, no new frequencies will be created. In the second case - what Jotto said.
  4. sribalaji
    Dec 15, 2011
    how should i visualize the resultant waveform?
  5. Potato Pudding
    Jun 11, 2010
    684
    92
    Using a circuit simulator comes to mind as the simplest way to get an image, or else breadboard and scope the signals if you have a lab with the right equipment.
    There are different Mixers but for the 50Hz and 60Hz you mentioned you can see the 10Hz beat frequency in the simulator circuit I have shown in the picture.
  6. hgmjr
    Jan 28, 2005
    9,030
    214
