mixing battery in a battery pack
Discussion in 'General Electronics Chat' started by mrel, Jan 25, 2010.
  1. mrel
    Thread Starter Active Member
    Jan 20, 2009
    98
    Hello
    I have Ryobi 18 volts battery pack found 3 bad sub -c battery in the pack.
    The battery don't have any marking say if it is a nickel -cadmium or nickel metal hydride battery,
    Since I don't know what kind of battery is in the pack ,if I were to mix in the pack with nickel -cadmium and nickel metal hydride battery, will battery pack work,take a charge?:
    There is total 15 sub-c @ 1.2 volts battery in the pack connected in series .
    Since only 3 battery is bad I hate to buy all new battery.
    There is two issue one don't know what kind battery in the pack,second issue is can I mix two different type battery in the pack ( nickel -cadmium and nickel metal hydride battery together)
    Thank for the help
    mrel
  2. retched
    Dec 5, 2009
    5,201
    313
    The lesser batteries will steal charge from the new batteries. You should replace all.
  3. Darren Holdstock
    Feb 10, 2009
    262
    11
    Yup, don't mix 'em. Even if they were all NiMH cells the differing characteristics would mean they wouldn't charge properly, and the weaker cells could be damaged during discharge in use. NiMH and NiCd definitely don't mix.
    You could try reconditioning the rogue cells with a few charge/discharge* cycles, assuming all the original cells are the same type, just in different states of repair. Use an NiMH charger - this will charge both these and NiCd types (not at the same time though!), whereas a NiCd charger won't charge NiMH properly or safely.
    * Don't discharge the battery pack below 1 V per cell to prevent "cell reversal", or discharge each cell individually. NiMH cells won't tolerate frequent deep discharges, but will benefit from the occasional deep cycle.
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    I too would advise against mixing NiCad and NiMH batteries. The charging profile for these to batteries are substantially different. If you are interested, you can go to www.batteryuniversity.com and find out more about the differences in the charging strategies for these two different battery technologies.
    hgmjr
