Mixing 3 audio signals + power amp
odinhg
Joined Jul 22, 2009
65
Hi. I just got an AY38910 PSG IC which have 3 audio outputs. I was thinking of using a LM386 to drive a 250mW, 8ohm speaker. But I was thinking of mixing the 3 outputs together first. I've made a schematic (attached) from different application notes and other resources on the web. Is it possible that the circuit will work? If so, is there any improvements I can do?
Datasheets:
AY38910
LM386
LM741
Thanks in advance :)
ifixit
Joined Nov 20, 2008
652
  1. Use a newer opamp. eg. TL072
  2. Decouple the LM386 input with 0.1uF.
  3. The opamp needs a negative 5 volt rail.
  4. If you don't need to invert the signal then eliminate the opamp altogether.
  5. Add a volume control to reduce the signal level. The LM386 will only need approximately 70mV max.
Good Luck
Audioguru
Joined Dec 20, 2007
11,248
The output of the sound generator (awful-sounding square-waves) has DC on it so it will bias the input of the opamp. Then the (+) input of the opamp must also be biased to a similar voltage. Then the opamp will not need a negative supply.
The output of the opamp will then have a DC voltage so a coupling capacitor is needed to feed AC audio but not the DC to the input of the LM386 amplifier.
