mixed of f what means in broadband
Discussion in 'Computing and Networks' started by lse123, Apr 25, 2010.
  1. lse123
    Thread Starter Active Member
    Oct 17, 2006
    87
    In broadband LAN / DSL exist many channels(in FDM many f) , well these channels [f] , does not interfere between each other, so if get mixed there is way to umnmixed? correct?
    mixed of f what means in broadband?
    in any grade, mixed, always there is way get originals signals(unmixed) back?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Too many things got mixed up. DSL is a means of sending data on telephone lines by using higher than voice frequencies and filters. LAN uses a different signaling method, although both and telephone signals are carried on UTP cables - http://en.wikipedia.org/wiki/Twisted_pair
    In both cases, data comes and goes in packets. The data packets contain information that allow multiple users to share the same sets of wires. http://en.wikipedia.org/wiki/Packet_(information_technology)
    In broadband, the packets are sent as modulations on a carrier frequency that is broadcast, rather than carried in a cable.
    In all cases, the individual packets may be identified by their headers, irrespective of the transmitting method.
  3. lse123
    Oct 17, 2006
    87
    the individual packets eg packet1=f1, packet2=f2... if mixed they do not destroyed?
    In any mixure there is alway way get original signls back? yes/no
    Finally mixed signals are get, transmitted as one signal come from many signals?
    we do not have contribution in differ signals[fs]?
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Here is a link to the concept of packets in TCP/IP - http://en.wikipedia.org/wiki/Transmission_Control_Protocol
    You will see that internal fields make it possible to see if any data corruption has been experienced. Even though the packets share the same cable or frequency, they are not mixed together, if I understand you properly.
  5. AlexR
    Jan 16, 2008
    735
    54
    The data segment of a DSL link is simply a high speed serial link. As with all serial data links the data (as IP packets in this case) is transmitted sequentially one packet at a time. There is no mixing of data packets during transmission.
  6. rjenkins
    Nov 6, 2005
    1,015
    69
    The DSL/ADSL system is frequency multiplexed.
    The available frequency, from a few KHz above the audio up to somewhere in the 1 to 2 MHz range, is divided into hundreds of slots or channels.
    Each slot is used for a separate data stream, one way or the other.
    The system is adaptive and each slot has the speed adjusted to match the line quality or interference at that particular frequency.
    You can think of it as something like masses of dial-up modems all on separate radio channels, but with the signal down the phone line rather than using antennas.
  7. lse123
    Oct 17, 2006
    87
    In broadband(frequency), why A packet from one frequency(f) can NOT mixed up with another f, I mean go to another frequency way, and get this other street(same cable)?
