I just bought an oldish condo which is hot water heated and has been retrofitted with AC. I want to install a single programmable thermostat in place of the individual mechanical thermostats for heating and cooling. The heated water valve is turned off WITH current (24VAC) and on with NO current. All common programmable thermostats want to turn it on WITH current and off with NO current. I have used the AC terminal (terminal Y) on a programmable thermostat to regulate heating successfully, pretending it's really cooling. However, this takes up the Y terminal on the thermostat, making it impossible to operate the AC.
Is there a way to reverse the current flow to the water actuator valve without spending a bundle? That is, when my thermostat switches on the current to activate the heater, I want the heater valve actuator to see no current, thus turning on and vice versa. This is a long explanation to explain a rather simple request so I hope that it's understandable.
