Mistake SMD part but shown through hole
Discussion in 'The Projects Forum' started by new122, Mar 22, 2013.
  1. new122
    Feb 5, 2013
    17
    Hello All,
    Need some serious help. One of our designer shows through hole pad and routing for one component. Now this production also done. Now we came to know that component is actually Surface mount not though hole. So how to correct this error, without reproduction/change part.
  2. tracecom
    Apr 16, 2010
    3,879
    1,396
    You can create a "breakout board," which is an adapter PCB with a footprint to allow the SMD to be soldered on, but also has pins out the bottom that you can solder to the holes in the main board. The breakout board has traces that properly connect the SMD pads to the through hole pins. Properly done, it doesn't look too bad, and works well.
    What is the SMD part number?
  3. mcgyvr
    Oct 15, 2009
    4,793
    976
    typically called "surfboards" or "breakout board" or "SMT to TH adapters"
    I like this place for that kind of stuff..fast shipping/great selection
    http://www.proto-advantage.com/store/index.php?cPath=2200
    or find a through hole version of the part.. That will be "cheaper"/more professional looking,etc.. for a production run by far.
  4. ErnieM
    Apr 24, 2011
    7,443
    1,628
    You can get adapters much cheaper off EBay.
    But your boss still isn't going to like this <grin>
    (PM me with size if you need a link)
  5. GopherT
    Nov 23, 2012
    6,330
    4,078
    Is there an issue with through-hole pins aligning to the SMD pins since the SMD is mounted to the back of the board and pins will mirror the surface mount pins.
