Missing tooth
Discussion in 'The Projects Forum' started by Teena123, Apr 15, 2013.
  1. Teena123
    Nov 22, 2012
    38
    Hello guys, I'm working on a toothed wheel with 40 tooth and 4 tooth missing with a VSR attached to it. the sine waves of the 4 missing tooth wheel appears to have a sine wave signal larger than the other 40 tooth, my problem is i want to build an interface maybe an inverter to change the missing tooth into a meeting pulse. Please does any1 have an item about this??
  2. WBahn
    Mar 31, 2012
    18,089
    4,917
    You are going to need to explain what you have, what you are trying to do, and how you are trying to do it much more fully and clearly. I have no idea what you mean when you say you want to change a missing tooth into a meeting pulse.
  3. THE_RB
    Feb 11, 2008
    5,435
    1,305
    It's an automotive camshaft sensor, they use about 48 teeth with one missing to give a pulse pattern so the engine control unit can sense cam position and timing.
    Decoding the cam and crank pulsetrains is normally used to build performance enhancing gadgets to modify the operation of the fuel injection etc, and is likely to be closed down because of forum rules.
    DerStrom8 likes this.
  4. Teena123
    Nov 22, 2012
    38
    This isn't a real tooth wheel for an engine it just works in the same way please do you know how i can do that??
  5. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Your thread will still probably be closed. The mods cannot know for sure that you're not trying to modify an automobile, and generally they just don't want to take any chances. Unless you give more, VERY SPECIFIC information on EXACTLY what you're trying to do, we cannot help you.
    Matt
  6. WBahn
    Mar 31, 2012
    18,089
    4,917
    Even assuming they don't shut it down, we need you to provide more information more clearly. Could you provide a sketch of what your signals look like both when the missing tooth comes around and when it's somewhere else?
