Missing number in series
Discussion in 'Math' started by ENE, May 6, 2016.
  1. ENE
    May 5, 2016
    6
    Hello Friends,
    how to calculate this :
    5205, 3008, x-------,948,605,480
    what will be x?
  2. WBahn
    Mar 31, 2012
    18,079
    4,917
    What do you want it to be?
    Pick a number and I can determine a fifth order polynomial that will produce that sequence of numbers.
    Similarly, there are other functional forms that can be used to generate a host of six-number sequences that would fit that pattern.
    ENE likes this.
  3. GopherT
    Nov 23, 2012
    6,297
    4,019
    UnHelpful and undoubtedly obvious to the OP. No way to prove the sequence with that when the textbooks with this type of question are generally looking for a simple rule-based step function rather than a continuous function.
    ENE likes this.
  4. WBahn
    Mar 31, 2012
    18,079
    4,917
    Trolling again, huh?
    ENE likes this.
  5. GopherT
    Nov 23, 2012
    6,297
    4,019
    Just following your lead - you are trolling the OP. Not helpful. When have you ever seen a missing number in a series question ask for a solution via a fifth-order polynomial solution? Trolling doesn't fit a Mod.
    ENE likes this.
  6. WBahn
    Mar 31, 2012
    18,079
    4,917
    Then the problem needs to state the bounds on the kind of relationship that is fair game -- which it may well do (by way of context of the material being covered in the section that this problem is associated with). But since I don't have a crystal ball I can't tell that unless and until the TS provides that information.
    There is a pretty simple rule-based function that can generate this function involving the cubes of a simpler sequence.
    ENE likes this.
  7. WBahn
    Mar 31, 2012
    18,079
    4,917
    I'm pointing out information about the lack of information provided. You are just going out of your way to act like an ass. You complain about someone saying something that is "unhelpful and undoubtedly obvious to the TS", which means that, by your own criteria, your post had to be even more "unhelpful and undoubtedly obvious to the TS".
    So troll away, I'll respond to the TS, but not to you any longer.
    thumb2 and ENE like this.
  8. WBahn
    Mar 31, 2012
    18,079
    4,917
    The next two numbers after 480 that the sequence is probably meant to have are 453 and then 452. Focus on those three numbers for a while.
    ENE likes this.
  9. GopherT
    Nov 23, 2012
    6,297
    4,019
    Lack of information? Teachers and textbooks have been asking for rule-based solutions to missing numbers in a series questions like this for the past 50 years or more. It is a standard. Why on earth would you expect the OP to provide additional information to a standard. Let me correct myself from above, you are not a troll, you are clueless.
    In case you were home-schooled and your mother skipped it, you can review the attached.
    https://www.mathsisfun.com/algebra/sequences-finding-rule.html
    ENE likes this.
  10. ENE
    May 5, 2016
    6
  11. ENE
    May 5, 2016
    6
    sorry....?
    what this mean?
  12. ENE
    May 5, 2016
    6
    605-480=125
    948-605=343
    343-125=218
    5205-3008=2197
    How to think for this series?
  13. WBahn
    Mar 31, 2012
    18,079
    4,917
    You are on the right track, but one of your numbers is not in keeping with the others.
    List the differences between successive numbers in the list. That would be 125, 343, and 2197.
    Do you see a pattern in those numbers?
  14. WBahn
    Mar 31, 2012
    18,079
    4,917
    Another way to approach a problem like this -- though like any such method it is not guaranteed to work -- is to plot the known points and see if it looks like a smooth curve could be drawn between them. If so, it is likely that a low degree polynomial can generate that curve.
  15. WBahn
    Mar 31, 2012
    18,079
    4,917
    What if your original list had been:
    5205, 3008, x-------,948,605,480,453,452
    Do the same thing you did before and see if a pattern is more obvious.
    EDIT: Corrected typo in last number.
  16. GopherT
    Nov 23, 2012
    6,297
    4,019
    You have a slight typo or math error, @WBahn , I get...
    5205, 3008, x-------, 948, 605, 480, 453, 452, 452
  17. WBahn
    Mar 31, 2012
    18,079
    4,917
    Clearly a typo, given the numbers in Post #8. Thanks for pointing it out.
  18. DGElder
    Member
    Apr 3, 2016
    347
    87
    The differences in the sequence are the cubes of a sequence of odd numbers.
    605-480=125 is 5^3
    948-605=343 is 7^3
    x-948 = 729 is 9^3
    3008 - x is 11^3
    5205-3008=2197 is 13^3
    x= 1677
    Don't ask me how I did it, no formal method, just trial and error looking for a pattern. And I assume in good faith that the author would not make it too convoluted and should be solvable with integers.
    ENE and GopherT like this.
  19. ENE
    May 5, 2016
    6
    Hello Sir,
    I have done it without watching thre next ppost thanks DG..
    it is 1677 same as you said to notice pattern.
  20. ENE
    May 5, 2016
    6
    How to make pattern ?
    4, 77, 498, 2515, 10076, 30237, .........
    77-4=73
    498-77=421
    2515-4982017
    how to solve these type of question in few second ?
