Missing beam circuit For IR Led and Diode
Discussion in 'The Projects Forum' started by amila133, Oct 30, 2009.
  1. amila133
    Oct 30, 2009
    5
    Hi all,
    I want to design the missing beam detection circuit with IR Led and IR diode.
    tell me about some example circuit?
    When I am designing what are the factors that should I consider.
    Thanks....
  2. KMoffett
    Dec 19, 2007
    2,584
    234
    For circuits Google: beam break circuit
    Lots of options out there.
    Considerations:
    The distance between the LED and IR diode.
    Beam-width/angle of the LED, and detection angle of the diode.
    Ambient light/heat sources that can be detected by the diode circuit.
    Ken
  3. AdamPrulhiere
    Nov 12, 2009
    14
    I made one of these in my circuits class. I was using an astable 555 timer to generate the IR pulse a monostable 555 to detect the missing pulse. I had some issues with the triggering of the monostable 555. If you take this approach I would look into the triggering of the monostable 555.
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    How much range? Do you want it to work outdoors in bright sun?
    I needed one that would work over a range of 3m, outdoors. I used a standard TV remote control IR receiver module (Sharp GP1U58Y) as the detector. I build a transmitter which modulated a IR Led at the carrier frequency (40kHz) to match the receiver. A momentary interruption of the beam causes the output of the IR receiver to switch low, and then high again.
