miss clara
Discussion in 'Homework Help' started by OCHUWA, May 12, 2010.
  1. OCHUWA
    May 12, 2010
    collector emitter voltage collector current
    VCE
    V IB=100μA IB=200μA IB=300μA 400μA 500μA
    0 0 0 0 0 0
    1 3 7 10 15 18
    2 4.8 10 12 19.6 23
    3 6 12 16.1 22 26.1
    4 6.9 12.8 17.9 24 28.2
    5 7.4 13.5 18.8 25 29.7
    6 7.9 13.9 20 25.8 30.6
    7 8 14.1 20.6 26.3 31.7
    8 8.1 14.3 21.0 27 32.3
    9 8.1 14.6 21.2 27.8 33
    10 8.2 14.9 21.8 28 34
    12 8.3 15.1 22.4 28.8 35
    14 8.5 15.3 23 29.4 36.2
    16 8.6 15.4 23.5 30.5 37.5
    18 8.8 15.5 24 31.2 38.2
    20 9.9 15.6 24 32 40
    Plot the output characteristics and use it to determine the output resitance, construct the load line for the transistor when the collector supply voltage is 18v and load resistance is 600Ω, identify the quiescent point on the graph and give the values of the quiescent current and voltage. develop a table from the transistor output characteristic curve for when Vce=10V and hence plot the transfer characteristic of this transistor. Evaluate also the gain of the transistor.
    please i need a guide to what i should do to solve this problem.
    thanks you
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    You can plot the graph (Ic vs Vce with fixed IB) in Excel - for instance. As shown in attachment. You should try doing this yourself.
