Misprint
Discussion in 'Feedback and Suggestions' started by phenderson, Mar 22, 2010.
  1. phenderson
    Nov 22, 2008
    My message below is not correct. I was confusing the diagrams referred to. Sorry.
    There is an error in Volume 1 - DC; Ohm's Law; Circuit Wiring; paragraph 4, 2nd sentence:
    This should read "....will be the same as the voltage between points 3 and 4 (directly across the resistor)."
    The sentence currently reads, "...between points 2 and 3..." which is incorrect.
    Paul Henderson
    Hamilton, Ontario
    Canada
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    You can delete posts you make. This is unusual for most forums, but I've been known to use it on occasion.
