Mirror Currents
Discussion in 'Homework Help' started by eestudent123, Feb 10, 2012.
  1. eestudent123
    Feb 10, 2012
    I have a question regarding the circuit attached below. Assuming that bettas are infinite and that Is2=N*Is1 since the emitter area of Q2 is N times larger than the emitter area of Q1.
    My intuition tells me that Iout=N*Iref, but I dont know how to put it in equations....
    There is no xurrent flowing along Vdd, is thia correct?
    Where should I start from?
    Thank you,
  2. Mark_T
    Member
    Feb 7, 2012
    47
    8
    This is a current mirror circuit, but in a mirror circuit beta is matched usually very closely by choosing adjacent transistors at the wafer fab house. So N=1. In yours the current will vary with N as described. Current does flow in the bases as they are forward biased and it is these that balence the the current as if the transistors are matched the base currents will be the same.
    By the way if beta's are infinite then you can't have N times it. Also you'd have a short circuit everywhere to ground!
  3. crutschow
    Mar 14, 2008
    13,472
    3,361
    No. A BJT with infinite beta will still operate as a normal transistor, with an output current proportional to the base-emitter voltage (it still would have a finite transconductance gain).
