minn kota trolling motor
Discussion in 'General Electronics Chat' started by ggmiles, Apr 5, 2009.
  1. ggmiles
    Apr 5, 2009
    I recently purchased a used bass boat and it has a minn kota trolling motor with 12/24 switch. I have only one battery; however, there are four leads in the battery compartment, 2 red and 2 black. There has never been two batteries installed. How should I connect the leads for one battery operation? Thanks,
    Jerry
  2. KMoffett
    Dec 19, 2007
    2,584
    234
    First I would contact the company...they have a web site...http://www.minnkotamotors.com/
    But off the top of my head, I'd say that each pair of Red/Black wires goes to a 12V battery. The 12/24 switch selects one battery for 12V and two in series for 24V.
    But since MinnKota has contact info...I'd just ignore me, and go there before I hooked anything up. :)
    Ken
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I would think a quick inspection of the terminals on the two sets of wires in the battery compartment would indicate which pair have been used, and which have not - unless the previous owner had been using two batteries.
    Does the boat itself have a 12v/24v switch? Or is the only switch on the trolling motor?
  4. ggmiles
    Apr 5, 2009
    Only the trolling motor has 12/24 switch. To clarify, the motor has its own starting battery and the trolling motor has its own battery. It appears that the previous hook up was both black wires were hooked to the negative post and one red wire was connected to the positive post.
    Thanks again!
