Minimum voltage in short arc flashlamp ?
Discussion in 'General Electronics Chat' started by matters_100, Apr 3, 2016.
  1. matters_100
    Mar 30, 2016
    15
    I have a linear xenon flashlamp, with a short arc (approx 2.4in/ 60mm) which is used in pulsed applications.
    Assuming that for a given voltage, the current is only limited by the lamp impedance K0.
    I was wondering, once already ionized, around which voltage the lamp would stop being ionized ?
    I read a long time ago, in a not so reliable source, that the minimum voltage should be 600v for a 3in arc length.
  2. Hypatia's Protege
    Distinguished Member
    Mar 1, 2015
    2,850
    1,317
    Such calculations in regards to confined arcs are complected by 'ignorance' of an all important 'factor' (To: wit inner-vessel pressure at 'arc temperature' [i.e. peak current plasma pressure]) --- So... unless said parameter (i.e. "extinction voltage @ Imax") is specified by the manufacturer, my best advice is that you determine same via a stroboscopic (i.e. 'recurrent discharge') circuit and an O'scope....
    Best regards and good luck
    HP:)
    matters_100 likes this.
  3. crutschow
    Mar 14, 2008
    13,519
    3,386
    A xenon arc lamp typically has a low voltage when operating (18-30V).
  4. matters_100
    Mar 30, 2016
    15
    Thks
