Minimum power supply for Arduino
Discussion in 'Embedded Systems and Microcontrollers' started by vindicate, Jul 15, 2009.
  1. vindicate
    Thread Starter Active Member
    Jul 9, 2009
    158
    Anyone know what the minimum supply I can use is?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It depends on the processor present and all the connected hardware. Check data sheets for the current figure - always plan on having a healthy reserve of about 50%.
  3. vindicate
    Jul 9, 2009
    158
    I was thinking more voltage wise. It has an ATMega328-PU. I'm not too worried about current at this point.
  4. nanovate
    Distinguished Member
    May 7, 2007
    665
    Try looking at the datasheet for the board. The micro can go down to 1.8V but the rest of the board probably either needs 3.3V or 5V plus if it has a regulator then you should add about 2 to 3 volts on top of it.
  5. John Luciani
    Apr 3, 2007
    477
    The ATmega328P will operate from 1.8V to 5.5V in. At voltages
    below 4.5V you need to reduce the operating frequency below
    the maximum frequency of 20MHz.Check the safe operating area
    graph in the datasheet.
    (* jcl *)
