minimum pin to drive 4 bi-color leds
Discussion in 'General Electronics Chat' started by bug13, Aug 31, 2016.
  1. bug13
    Feb 13, 2012
    1,214
    38
    Hi guys
    What's is the minimum pins I need to drive 4 bi-color leds? I have some d-latchs, inverters. But I don't have shift register. The bi-color leds are common ground/cathode.
    Thanks guys!
    NOTE: the least I can come up with is 6 pins, in a multiplexing arrangement.
  2. hp1729
    Nov 23, 2015
    2,103
    233
    No transistors?
  3. hp1729
    Nov 23, 2015
    2,103
    233
    Each LED can be turned on individually so you can have red, green, yellow or off.
  4. hp1729
    Nov 23, 2015
    2,103
    233
    You have latches? You can have red or green but not yellow or off.
    Use the current limiting of the high side driver as the LEDs resistor.
  5. hp1729
    Nov 23, 2015
    2,103
    233
    All the same color? Red, green, yellow or off.
  6. bug13
    Feb 13, 2012
    1,214
    38
    Thank you all!!
    And yes, I can use transistors diode and something like that.
  7. dannyf
    Sep 13, 2015
    2,196
    417
    depending on the led used but 3 pins (two drive pins and 1 ground/rail) will produce (theoretically) unlimited colors.
  8. hp1729
    Nov 23, 2015
    2,103
    233
    What kind of LEDs do you have? 3-pin with a common cathode can only get two LEDs. The "any color" LEDs I have seen have 3 LEDs and 4 leads. Do you want "off" to be an option?
  9. bug13
    Feb 13, 2012
    1,214
    38
    I will need 3 states:
    Green
    Red
    Off
  10. hp1729
    Nov 23, 2015
    2,103
    233
    Individually controlled? I suggest the 74259 version unless you need high brightness. There is a CMOS version of the chip but I don't think the high side driver would drive them.
