w or zbar is the expression though? Is that incorrect?? it's product of sums. What should it be? Wow I'm so confusedWhat expression do you get from
You got
You got
Is this consistent with the rest of your outputs?w or zbar is the expression though? Is that incorrect?? it's product of sums. What should it be? Wow I'm so confused
Yes, unless I'm seeing things again.LOL. I was so worried I was like yea I'm about to just give up on this EE class hahaha. So my answer is correct?
But I can't tell which variable maps to which bit when you state:What? WX is my columns and YZ is the rows...
These correspond to the rows, as you will see on the left and right 00, 01,...etc. The rows start from 0 to 15. For example the top left cell is 0, the cell to the right of it is 1 the cell to the right of that one is 3, but the cell to the right of that one is 2, So basically you start out in sequences until you get to the 3rd number. so m(0,1,2,3) on the kmap looks like this: (imagine there are blocks for the KMAP)But I can't tell which variable maps to which bit when you state:
m(1,3,4,5,9,10,11,14,) + d(0)
+d means that every where the column is mentioned for d you put a "don't care" there.And I still have no idea what you mean by "+ d(0)"
Never did I ask anyone to guess anything. Yes, thank you for stating the obvious, engineering is not a guessing game. You should also take into account that if you have no idea of what I'm asking or talking about then you yourself - should refer to your own statement before blasting me. I can't explain Calculus to you if you don't know how to do pre-algebra. If you don't know what d means then you obviously have never worked K-MAPS nor can you help me. So you should really think before you post ignorant statements. Luckily tschuck does know what he is talking about and verified my answer.Don't make people guess what you mean. Engineering is not about guessing.
Just because I have not seen your particular notation for "don't cares" hardly means that I have never worked with K-maps.These correspond to the rows, as you will see on the left and right 00, 01,...etc. The rows start from 0 to 15. For example the top left cell is 0, the cell to the right of it is 1 the cell to the right of that one is 3, but the cell to the right of that one is 2, So basically you start out in sequences until you get to the 3rd number. so m(0,1,2,3) on the kmap looks like this: (imagine there are blocks for the KMAP)
0 1 3 2
4 5 7 6
12 13 15 14
8 9 11 10
Thanks,
Sham
Yea bro, cool entry for how to get the SOP & POS. I'm talking about 4-input K-MapsJust because I have not seen your particular notation for "don't cares" hardly means that I have never worked with K-maps.
I was going to suggest you that you look at the following blog entry:
http://forum.allaboutcircuits.com/blog.php?b=583
But since I have obviously never worked with any of this stuff, don't bother.
A K-map is just a graphical implementation of boolean reductions...Yea bro, cool entry for how to get the SOP & POS. I'm talking about 4-input K-Maps
Thread starter | Similar threads | Forum | Replies | Date |
Examples of Boolean minimization | Software & IDEs | 8 | ||
Z | DFA Minimization: Marking Procedure | Homework Help | 4 | |
Product Of Sums Minimization | Homework Help | 1 | ||
N | stuck with machine minimization problem | Homework Help | 3 | |
S | Minimization POS K-Map 4-Input | Homework Help | 3 |
by Aaron Carman
by Jake Hertz
by Jake Hertz
by Duane Benson
