Minimization SOP K-Map 4 input
Discussion in 'Homework Help' started by Shamieh, Feb 13, 2014.
  1. Shamieh
    Oct 24, 2013
    36
    Was wondering if someone could check my work.
    q) Using KMAP write out the minimal SOP Sum of Products m(1,3,4,5,9,10,11,14,) + d(0)
    My solution: w~xy + x~z + ~w~y
    q2) Using KMAP write out the minimal Product of Sums equation \pi(3,4,5,7,8,12) + d(13)
    My solution: (~w + ~x + y) (w + ~z) (w + x + ~y)
    Thanks in advance.. You all are always very helpful.
  2. tshuck
    Oct 18, 2012
    3,531
    675
    Nope, without seeing what you did, we can't verify if you did it correctly. Provide a picture of your K-maps and groupings and we can...
  3. Shamieh
    Oct 24, 2013
    36
    Oh. Sorry about that!
    SOP
    POS
    tshuck likes this.
  4. Shamieh
    Oct 24, 2013
    36
    Any idea? I'm about 91% sure I'm correct lol.
  5. tshuck
    Oct 18, 2012
    3,531
    675
    Your expression doesn't match with the K-maps you posted, did you make the K-maps, our did you derive the function from the K-map?
    Also, you should always list what the order of the variables is.
  6. Shamieh
    Oct 24, 2013
    36
    I used groupings to get the minimized function on the K-Map. What do you mean? I didn't make the K-MAPS they were already made, I just circled groupings for each and then put that corresponding term. Also, they are in order so I'm not quite sure what you are talking about? WX / YZ = x1,x2/x3,x4 essentially. So what do you mean exactly?
  7. Shamieh
    Oct 24, 2013
    36
    Tshuck I'm an idiot. I wrote the previous questions out wrong when I was telling you all because I read the column rows incorrectly. Thanks for pointing that out. As far as the grouping and terms I got.. Is that correct? Im going to edit my very first post right now so it will be clear what the question is stating, even know it;s visual
  8. WBahn
    Mar 31, 2012
    18,093
    4,920
    What is this "+d(0)" and "+d(13)" that you have in there?
    Be explicit about your mappings -- don't assume that people that normally read left-to-right are going to assume the same mappings as people that normally read right-to-left.
    One simple way to do it, which usually works fine, is something like this:
    m => msb {wxyz} lsb
  9. tshuck
    Oct 18, 2012
    3,531
    675
    Don't care terms
    I usually write it as m(W,X,Y,Z) = 1,2,3,4,5, etc.
  10. Shamieh
    Oct 24, 2013
    36
    So is there anyone here who knows if my answer is correct? lol
  11. tshuck
    Oct 18, 2012
    3,531
    675
    That is correct.
    I would say you should check this one again...
    Shamieh likes this.
  12. tshuck
    Oct 18, 2012
    3,531
    675
    You could always check it yourself by writing out the truth table for the function you end up with and comparing it with the original...;)
    Shamieh likes this.
  13. Shamieh
    Oct 24, 2013
    36
    What other grouping could I possibly make though? I don't understand
  14. tshuck
    Oct 18, 2012
    3,531
    675
    It isn't the grouping, it's the interpretation of it.
    Shamieh likes this.
  15. Shamieh
    Oct 24, 2013
    36
    Editing. Be right back
  16. tshuck
    Oct 18, 2012
    3,531
    675
    These aren't even the same values...:confused:
    EDIT:Looks like you realized this as I was posting....
    Shamieh likes this.
  17. WBahn
    Mar 31, 2012
    18,093
    4,920
    I'm not going to bother even looking until you specify your mappings.
  18. Shamieh
    Oct 24, 2013
    36
    Sorry was looking at the wrong problem for a second...But I am completely lost on what you mean
  19. tshuck
    Oct 18, 2012
    3,531
    675
    What expression do you get from
    You got
      File size:
      237.8 KB
      62
  20. Shamieh
    Oct 24, 2013
    36
    What? WX is my columns and YZ is the rows...
