Miniaturised GPS tracker
Discussion in 'Wireless & RF Design' started by layxide11, Sep 29, 2016.
  1. layxide11
    Jul 30, 2015
    18
    Please i want to build a miniaturised GPS tracker. I wnt it to recieve very low GPS signals and send to as far as 2km. I need help on possible receivers, and transmitter designs.
  2. blocco a spirale
    Jun 18, 2008
    1,455
    369
    Have you designed or built anything like this before?
  3. layxide11
    Jul 30, 2015
    18
    No i haven't
  4. GopherT
    Nov 23, 2012
    6,297
    4,019
    What tools do you have?
    What level of training do you and your team have?
  5. Papabravo
    Feb 24, 2006
    10,338
    1,850
    I'm quite sure that you cannot achieve your objective in any reasonable time frame. If I were you I would start by purchasing a 4 year degree in Electrical Engineering. It is kinda like trying to build a 12-foot telescope mirror without building mirrors 2, 4, 6, and 8 feet in diameter.
  6. DickCappels
    Aug 21, 2008
    2,746
    665
    That should not be terribly difficult for somebody with a little bit of electronics knowledge and the ability to write or copy a little software. Hobbyists and students are using the Arduino platform to experiment with the main components that you would need.
    A GPS "shield" for Arduino systems
    A 433 MHz transmitter and receiver for Arduino
    Admittedly, the 2 km range might be the difficult part. That probably boils down to selection of the transmitter and receiver involved. The transmitter/receiver pair to which I linked above is just an example of something you can get "on the air" quickly.
  7. Papabravo
    Feb 24, 2006
    10,338
    1,850
    I agree that the indicated devices are useful for experimentation, but how does he design and build the miniaturized version from scratch? Maybe the TS's concept of miniaturized doesn't correspond to any generally accepted definition.
  8. blocco a spirale
    Jun 18, 2008
    1,455
    369
    The ability to copy software and hang some modules off an Arduino isn't going to result in something that could be considered "miniaturised" by modern standards and a license-free telemetry link that will cover 2km probably doesn't exist. This is one of those situations where if the TS had the ability to complete this project he would already have done it, or at the very least part of it, but he doesn't even have anything that could be regarded as a loose specification.
    Papabravo likes this.
  9. DickCappels
    Aug 21, 2008
    2,746
    665
    Of course you both have valid points. Consider that with the referenced information the TS can at least get a start and begin to deepen his understanding of the issues involved. It may help to read my signature line.
  10. Papabravo
    Feb 24, 2006
    10,338
    1,850
    I never said it could not be done. I said I don't see how the objective could be realized in a reasonable time frame. I can be more precise. I would estimate a minimum of two years of development and experimentation at a minimum based on the information I have so far. I'd be surprised if anyone thinks it can happen quicker.
